how long is the VRM1 strip on a 290x?
1 May 2013
M28
290X VRM Questions?
How long is VRM1 strip, Just need to know to calculate how many heatsinks to order.
also see this chap has put some tape over, what I think, are resistors prior to heatsink installation, is this a good tip, what type of tape to use?
Don't have the exact length but it's the same length as the 7970's vrm banks, there is a few pics in this thread with heatsinks on top that will give you an idea:
http://forums.overclockers.co.uk/showpost.php?p=23576561&postcount=314
http://forums.overclockers.co.uk/showpost.php?p=23761645&postcount=320
And here:
http://www.kitguru.net/components/cooling/zardon/arctic-accelero-xtreme-7970-cooler-review/5/
Depending on what heatsink you are using, this is the best air vrm cooling you can get imo and what I'm using on my 290X:
Alpenfohn vrm sink(the beast) sitting under a modified AC Xtreme:
YOUR BASKET
1 x Alpenföhn Passive DRAM / VRAM Chip Coolers £11.99
I think the tape that guy has used on the resistors is just a precaution against potential shorting from perhaps using low profile heat sinks or he was maybe worried a heat sink would come loose and cause a short. Looks like regular old sticky tape to me, probably not a great idea, those caps can come loose fairly easily.
