how long to get to Emirates stadium from Finsbury Park? and how?
Then get the 6:50pm canoe, paddle past the sharks, avoid the red indians with arrows, go over the waterfall and you'll pop out the water fountain by the ground.
Simples.
well i'm hoping to get there at 7.20pm for a 7.45pm start
Depends which exit you go out from the train station. If its by the Arsenal World of Sport, then just cross over the road ( you'll see a william hill on the right hand side).
Turn right after you have gone past it then go down the road untill ur by the flats (also arsenal's old ground is in front of you), take a right, follow it round then take a right to go up the steps ( by this point you should be able to see the ground easily).
This is the way i go for the blue quadrant.
Hope that helps you!
P.S it will take between 10-15 mins!
Cheers Foz.
Greenlizard, you need to work on your jokes. I would stay inside and not talk to anyone for a few days.
