how long
Permabanned
19 Dec 2006
do you think it will be untill the 640 gts and x2900 512 is about £200 inc vat ?
im umming and arring if its worth upgrading now or waiting.
my 1950pro wont run bf2 maxes out very fluidly, stutters a bit which is a no go'er when your a sniper.
cheers
Are you sure it's not just down to drivers?
The 1950pro should handle everything BF2 has to throw at it, even at 1600x1200 and above.
^Indeed 1950 pro should get around 80fps and no stutter.
My 6800gs runs it fine maxed out @1600x1200, 4x aa, max ingame af @ 40 fps and no stutter at all.
even the 256 one ?
im on the latest drivers and ati ccc.
It will run bf2 maxed out, but for instance when you see a sniper running you dont see him running but more fading in and out, ie not running a certain speed but speedin up and slowing down, like it would on a 600 ping (yet im pinging at sub 80)
twas fine with the other cards.
so i have it on medium...
