How loud is phases change?
Suspended
19 May 2003
I have a chance to get hold of a chilly1 phase change unit, but it just occured to me I have no idea how loud it is, and tbh wouldn't want something that made a lot of noise.
Obviously it's not silent, but can anyone give me a rough idea of how much noise phase change makes? I think the compressor is a danfoss n11f if that helps at all.
The NL11F is exceptionally quiet, there is nothing better than it. The FR8.5 in the Vapo LS is a bit louder but i don't view it as noisy although some do.
If it's a bespoke Chilly1 unit then it'll be using an Embraco or Tecumseh compressor, similar in noise to the FR8.5's in the LS.
Any other custom build depends on the compressor, the Danfoss SC series are probably the most noisy of all piston type compressors.
Is this is one of the 402 xtremes on a well know auction site? If so the seller is pazza316 on xs, not much is known about those units...
