How many and where should i put the fans
29 Mar 2006
Hi All
I currently have 5 Fans on my case,
1- at the back blowing out
2 - PSU that suck in from underneath
3 - A normal fan suck in from underneath
4 - Intake from the front
5 - CPU Hydro H60 V2 High Performance Liquid CPU Cooler on top of the case blowing out.
Is this tooo many?? can i reduce?
Build -
i7 CPU 2011
Gigabyte Motherbored (cant remeber the model UD3 or summint)
16GB Ram again not sure on the make
980Ti GTX
Samsung 850 Evo
4 x 500 GB storage drive.
I have a case cosair big tall tower
Thanks
You could possibly remove the intake from the bottom.
I have way more fans in my case, but am not too fussed over noise vs cooling efficiency.
What size are each of the fans you have?
