How many artifacts?
4 Sep 2005
London
Hey all
Just giving my card another overclock (X800XT-PE + VF900), but when i get to 585 on the memory, it reports 1 artifact...
I just would like to know if 1 artifact can actually do any damage? If not.. how many is bad? :)
Thanks
weescott said:
Good question.
IMO 1 artifact means 1 artifact too many. Up volts by the minimum and u will be fine.
Erm... I think dropping the core down by 5mhz would be the safer option to volt modding the card :/
posting on an overclocking forum by default means taking risks unless otherwise stated. In my opinion. And since the OP is overclocking I don't see that taking risks is a problem unless stated otherwise.
Hard modding is not something to be taken on a whim though.
As said, drop the clocks back a bit, unless you are handy with a soldering iron.
Tom
