- 27 Apr 2007
For maximum competition with the mainstream platforms Intel need to add more cores to compete with AMD.
If you look at a Coffee Lake die the GPU takes up about the same space as 4 cores.
So that gives the option of 10 core with no graphics or 8 core with very cut back graphics using the same die size as the £150 i5-8400.
Moving onto 10nm and ignoring the disaster that has been but just looking at the density improvements and that allegedly will be well over doubled.
In other words they could put out a 16 core with graphics on a die size less than the i5-8400 or 20+ cores with no graphics.
To match that Zen 2 would need to use an 8C CCX unless they put out a TR style chip for AM4 using a MCM design.
I'm not speculating on what will actually happen but the idea of both Mainstream platforms having 16C chips starting at £200 or less isn't that wild based on die sizes as they aren't exactly monolithic designs.
It makes sense to me for the mainstream high end design from Intel to cutback or remove the GPU and focus on more cores.
The mid range design could keep the GPU to CPU ratio the same or weight it a bit more towards the CPU.
I'd like to see them keep the GPU but with a much reduced EU count so you still get most of the features that make it useful for non gaming stuff.
If all this came to pass what great competition there would be for us consumers to benefit from.
