Simple question really, but what is the risk (if I can call it that) for a new LCD to have dead pixels? At the moment I have an Iiyama 17" LCD which has no dead pixels, and I'm toying with the idea of getting a 20" widescreen Viewsonic VX2025. The biggest turnoff would be if the new screen had dead pixels, and if this would be below the treshhold at which the manufacturer swaps it. In Viewsonic case the policy is:
"If the monitor has a full dead pixel (black or white) then the unit will be swapped out. If the monitor has sub pixel failures (Red. Green or Blue) then you are allowed a max of 10 before the unit can be swapped out, this in compliance to the ISO 13046-2 Part 2, pretty much all the manufacturers adhere to this standard".
So, what's the risk that I'll be staring at a dead pixel and is it worth the risk?
. setup on arriving home, this panel has replaced my SONY HS95ps panel (My farther is now well happy) due to that panel being soooo slooow. on switching on I was glad to see that there were NO dead pixels (Sony had 1 sub blue). This monitor is megga bright so I have reduced the brightness from 100% to 50%, Backlighting is very even across the panel. A downside of this panel is there in no backlight adjustment or gamma settings.
