How many errored seconds per day is 'acceptable'?
18 Oct 2002
My speed touch 585v6 is synced at 8128/448 and has an uptime of 12 days (since i installed it and turned it on). However, i get, on average, 700 errored seconds a day. The connection is stable and the speeds goof (700k+ from quick sites), but should i be concerned about the level of errored seconds and use DMT to get my router to sync at a lower speed?
Many thanks
Spudgun
As a percentage of the 1440 minutes a day les than 12 doesn't seem so bad does it ?
*edit* 0.83% error rate *edit*
I think the general rule here is if it ain't broke, don't try and fix it ;)
If you aren't getting corrupt downloads, your speeds are good and pings are fine then I'd just ignore them.
