how many fans can i run on this build?
26 Sep 2013
here my build http://prntscr.com/219utw (its a screenshot)
so in my case there are 8 fan mounts. 2 have been preinstalled and there are 6 available.
my mobo only allows me to connect 2 fans on it (including the cpu fan) so there are 7 fans that i can still mount.
i just want to know if that if i install all 7 fans and run them will my psu be suffice?
i wont be installing all 7 fans maybe just 2-3 extra.
You will be fine, 7 120mm fans at around 0.2amps each will only draw an extra 1.4amps or 15w total.
Edit: If you already have the fans it will say on the back what amps they use, if not you can check this before buying,
