How many fans in your PC?
1x 200mm intake
1x 140mm intake
1x 200mm Top
1x 140mm out the back
And one 140mm on the heatsink, and a little crappy one on the GPU.
I have 9 fans.
2 on H80i Push & Pull
2 120mm Front Intake
2 120mm Top Outflow
2 120mm Side Intake
1 120mm Bottom Intake
1 on GTX 680 ,but I don't think that counts really;)
2 140s at the front
1 140 at the bottom
3 140s at the top
1 140 at the back
2 140s on the cpu
2 80s (not sure about this) on my sli'd 670 gtxs
2 35s on the sabertooth
1 140 in the ocz zx 1250 psu
14 in total
1x 120mm intake on front
1x 140mm exhaust on top
1x 140mm exhaust on back
2x on graphics card
1x CPU cooler
1x PSU fan
Total = 7 (3 case fans) :)
1x CPU fan
1x 120mm intake
1x 120mm exhaust
1x 280mm side fan
1x fan on EVGA SC 660
2x PSU fans(the usual out the back and a bottom fan)
aaaaaand ..... mmmm no, thats it :)
7 Fans in total... but when running in silent mode, it is barely noticeable :)
Only 3 in mine (plus the graphics card)
1x 200mm exhaust (top)
1x 200mm intake (front)
1x 120mm intake (back, for H70)
Then PSU + Graphics Card (6950 Twin Frozr III so 2 fans on that)
So only 6 in total. Not sure what my loudest part is, a small noticable noise but it doesn't bother me as i usually have music on.
2x 120mm cpu fans
3x 120mm front intake
1x 120mm floor mounted intake
1x 140mm rear exhaust
2x 120mm top exhaust
3x gpu fans, (wf 670 x3)
1x psu fan
13 in total, my case has more fans than my local football team. All are ran via a mixture of PWM, 3 pin board headers and a fan controller.
So far only 3 in mine (although I might replace one.
1 x 120mm Corsair as front intake
1 x 120mm Corsair as rear exhaust
1 x Coolermaster PWM on my HS as push.
Thinking of swapping it out as I have a Gentle Typhoon 1225 sitting here
Front 1x200mm intake
Top 2x140mm exhaust
Rear 1x120mm exhaust
Cpu 1x120mm&1x140mm
PSU 1xFan
7 in total
2x120mm on the front radiator
1x120mm on the front drive bays
2x120mm on the rear radiator
1x120mm in the psu
1x120mm on the rear drive bays.
Front Intake: 4 x 120mm
Top Exhaust: 2 x 120mm
Rear Exhaust: 1 x 120mm
All fans are: Xigmatek XAF-F1251 Blackline Fan's
7 in total.
Additional: 1 x Stock GPU fan & PSU fan.
Front Intake 2x 140mm
Top Exhaust 1x 120mm, 1x 140mm
Rear Intake 2x 120mm (H80i)
5 in total, with overall positive airflow in the case.
Additional: 3x GPU fan and the PSU fan
Ordinarily:
Intake: 2 x AF120
HDD cage: 1 x AF120
CPU: 2 x SP120L in push mode (H100i)
GPU: 1 x Stock AMD
Exahust: 1 x AF120
PSU: Stock Corsair 140mm fan
Currently however the H100i is awaiting RMA so I've had to go back to the stock AMD cooler, which is noisey :(
