hey all,
trying to wire all my fans up automatically controlled via speedfan. i have my gpu/radiator fans wired up to the 2 pwm slots on my board (3pin fans) and my intakes are on a 3pin which for some reason i cant control. i currently have the gpu fans (7950 dual fans wired to 3pin) and a 120mm nzxt fan on one pwm header and two 120mm xigmatek fans on the other. i have 2 coolermaster (120/140) fans on the other and im wondering if it's safe to hook that up to the pwm slot with the two xigmatek fans so itd run like
splitter - 2 coolermaster fans
header > splitter >
splitter - 2 xigmatek fans
im pretty sure ive seen people run more than 4 on wc loop builds so im wondering if thatll be fine on a gigabyte gaex58-ud5? cheers
damn formatting ****ed it up but itd be a splitter with two splitters on that then 2 fans on either
header > splitter >
