How many PCi Express Cables Should I use?
8 Dec 2015
Just purchased a new Corsair AX860. I was wondering if it makes any difference on this PSU regarding the PCI graphic card cables. I have an AMD R9-390 GPU which has an 8 + 6 pin sockets.
Can I use just one cable from the PSU that has both the 8+6 to the GPU or should I use two separate cables from the PSU, thereby using two PCI slots on the PSU?
The reason I ask is because it seems some people use two separate PCI cables from the PSU if their GPU (Like mine), has two power connectors. In my case, an 8 pin and a six pin. Some people use a single splitter cable from the PSU and some would rather use two separate cables. I agree about cable management but does using two cables help distribute the load? My R9-390 as a TDP of 275W. Maybe more than one cable is preferred on multi-rail PSUs?
I'd use the cable as its intended and save the mess.
Its on them to supply accessories and a psu that works. If a double plugged cable for a gpu is included it makes sense to use it.
I suppose it could help to balance a load on a multi rail psu but as yours has a single 12v rail it makes no difference. If it wasn't designed to be able to power a gpu using a single power lead then the cables would only have a single plug on them. What about people with multiple cards that need to use every cable to power the gpu's? Stop worrying and enjoy your pc.
If you want a definitive answer email Corsair. They will tell you the same thing we have though. You have a high quality, single 12v rail psu and there will be no downsides to using a single cable to power the gpu. There are no advantages to using a pair of cables but you get the disadvantage of having more cables to sort out.
