How many X570 Motherboards are there without a Motherboard Fan ???
  • Thread starter Thread starter Deleted member 251651
  • Start date Start date
Hi,
Was wondering, what AM4 X570 motherboards are available on the market without the motherboard fan?
I know the X570 Aorus Extreme doesn’t have the fan on the motherboard.....but was wondering what other offerings there are if you were to build an AMD system for like the 5900x?
I think that’s only available on the more recent and much more expensive X570 boards.
It’s nothing to worry about (if that’s why you’re asking). I have the MSI X570 Tomahawk and it never spins up.
Hi,
the X570S range.
This.
Have the same board, and it only spins up on boot for a few seconds. And even when it does, I can't hear it.
As mentioned above look out for boards that refer to x570s - it's not a different chip set, the s just denotes that they're passively cooled. I've recently bought a gigabyte aero for my white build and it's doing ok so far.
Unless you want to run more than one PCIe gen 4.0 nvme then the B550 boards are all fan less, cheaper and will all handle a 5900X bar the a couple of the sub £100 ones.
