How much can I build a PC for that will run battlefiled 3 ultra or near ultra?
24 Apr 2009
Hi guys. Going to be building a new pc in around april time that will be good enough to run battlefiled 3 on ultra or very close. I will be using an intel i5. I only need the base unit, already have screen, peripherals etc.
I was thinking in or around £500 - £550, is this realistic or can it be done for cheaper? Case doesn't have to be spectacular though I would like cable management, I also already have 8G of new ram from my mates PC.
Any ideas or help would be much appreciated guys!
Thanks,
Marty
Something like this, although prices will vary, especially in 3 months time.
YOUR BASKET
1 x HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) £239.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £167.99
1 x Asus P8Z77-V LX Intel Z77 (Socket 1155) DDR3 Motherboard £84.98
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £69.98
1 x Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK) £49.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £677.02 (includes shipping : £11.75).
It would also help if you had some other components you can reuse, from an existing PC.
How does 7850 compare to a GTX 580 @ 850 core as i can tell you now i get dips to 45 sometimes in certain areas like the streams or overlooking entire map.
This is with 99% GPU usage and a 4600MHZ 3570K so my GPU is bottlnecking me in BF3.
Just a thought.
