How much difference - Current or proposed system.
1 Dec 2005
Stoke on Trent
Current spec in sig.
Looking to get :
CP-127-IN Intel Core 2 DUO E6400 "LGA775 Allendale" 2.13GHz (1066FSB) - Retail (CP-127-IN)
£139.99 £139.99
MY-034-GL GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) (MY-034-GL)
£129.99 £129.99
MB-179-AS Asus P5NSLI nForce 570 (Socket 775) PCI-Express DDR2 Motherboard (MB-179-AS)
£69.99 £69.99
Subtotal £339.97
VAT £59.50
Total £399.47
Will i notice a difference or should i stick with what i have. I neec the SLI board for my gfx cards :)
Hiya mate
IMO not worth the £400 it will cost you, unless you can justify it!
How much do you value £400?
Cheers :)
County said:
Hiya mate
Cheers :)
Quite a lot, but shouldnt cost that much after the sale of the 939 stuff. Could even flog one of my 7900GS cards to break even
Thats a different matter all together then :D
Although, i still wouldnt cause you already have a great rig, and what more could you do by "upgrading"?
If you do though stick it up on MM and i will nab the CPU off you ;)
Cheers :)
