how much difference do fans make on a single rad?
13 Sep 2010
Hi guys, first, apologies for mentioning closed loop systems in the WC subforum!
I have a Corsair H50 (1st Gen), which I used to run on a pair of akasa apaches (the old brown ones).
When I rebuilt my machine into my new case, I wanted to stick to a colour scheme (white/light blue) so went with some cheap arctic cooling PWMs. they are a bit noisy at full whack, although with my CPU at sock, they are still more than ample to keep it running, so I guess what my question is, is would there be any benefit to swapping out these for a pair of Scythe GTs (I think I could handle they grey, but if not, I've seen a lot of people painting them, looks do-able!) or are there any other white/blue themed fans I should consider, or would I be better off just sticking with what I've got now and just not turning them up as high.
I realise most of this is entirely subjective, but opinions are welcome!
Synthe GTs are better fans (quieter and better performance) but SP120 look nicer.
I would say they are quieter but in terms of performance about the same on most radiators. Comparisons i have seen slightly favored GT's with low to moderate FPI radiators and SP120s with high FPI (like the stealth rads).
I think between them, go for whichever give you more peace of mind.
