How much difference do mouse mats make?
21 Oct 2010
I'm thinking of buying the Boogie Bug AimB.Pad XL on this week only, but not sure how much difference it would make? Can I expect better sensitivity?
Thanks,
ng93
Depends on what you are using now, Boogie makes sure your keyboard doesn't slip and is nice. Can't tell the difference between it and a Razer mantis mat.
Thanks,
ng93
Better accuracy yes but at the same time it's not going to make you pro overnight.
Change is the worst thing when it comes to a gaming setup but yeah I would recommend a good mat and the boogie bug is v popular I have one but dont use it for my mouse.
It's the same as a good 'gaming' mouse, a pro will still pwn you with a DELL standard mouse but these things can make things feel more natural and therefore improve ur overall play.
If you're going to pay premium money for a mouse you might as well spend a tenner more on a mouse mat at least.
I've always found its worked a lot better for me as my desk is a painted bit of mdf and so not great all around for using a mouse on. Would jump and not respond very well etc. So for me it defo does make a difference.
And I've recently upgraded from a razer mantis speed mat to a boogie bug XL as well and it's working great :)
Looks like OcUK will be getting another sale then ;)
Cheers guys :)
p.s. the mat is as much for pro apps as it is for gaming, i'm not expecting it to make me a pro FPSer :p
