Is it a case of low end boards will never achieve the same results as high end boards, or is it luck of the draw with low end boards and more certainty in high end boards? Aside from that, how much difference will it make?
I was planning an upgrade from my i5 3570k to an i5 8600k until I saw the price of memory, it's not like I need to upgrade, I can wait to see if memory prices come down. Instead I decided to push my current CPU as hard as possible, bought a be quiet! silent loop 280, an aerocool aero 1000 case so I had somewhere to mount the radiator, and some coollaboratory liquid ultra for a delid.
The best I managed before, with a coolermaster 612, was 4.3ghz, around 1.3v, occt temps would sit around 78-80 but one core would get up to 85 occasionally, after swapping to the new case and cooler I've got up to 4.5ghz, 1.42v, occt has the temps sitting around 65-69, max has been 73, still haven't delidded, the 3D printer is just finishing off the delidding tool as I type!
It's not much use to me this time, I'm hardly going to buy another motherboard just to see if I can get a bit extra out of it, but I'm still planning on upgrading, just not right now and it'll probably be an i5 9xxxk or later by that time, but this will still be as relevant then as it is now.
If, for example, I bought an 8600k, a z370 hd3 and a z370 gaming 7, would I likely see a higher overclock in the gaming 7 compared to the hd3, with the exact same processor, memory, psu, etc?
