How did you manage to get "brake" right in the subject, but spell it as "break" in the post...![]()
Wouldn't imagine very expensive. £3-50 for parts.
An hour or two labour?
Which brake lines? Rubber ones to the Caliper or the ones routed underneath the car?
underneath the car mot guy said they have slight corrosion so i should keep an eye on them.
