How much do I need to spend?
16 Mar 2010
I want a 144hz monitor, only 1920x1080. Not sure what I'm looking for in monitors really. How much do I need to spend to get a good price/performance ratio? Thanks
I'm looking for one too, similar resolution don't want to go too high (strain on GPU)
Another aspect whether you want freesync or g-sync.. that means locking yourself into that brand of GPU. Stupid idea this...ideally should be a standard, or monitors support both.
Also you've got panel types each have pros & cons ie TN better for gaming but IPS better for video and angle
Cheaper the better I'm just looking for best bang for buck really, if that means spending a little more than so be it.
Would you be able to recommend a bunch at different price points? Id appreciate it!
Atm I'm 24" it's big enough but would go bigger, but not fussed.
