How much do your temps drop if you slightly open a window?
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
(The CPU fan speed reported is wrong as I have a H80 and the block is set to the lowest mode for both fans)
I lose 5 degrees all round, not that it was needed anyway :p Was just quite surprised because I remember losing more when I had the Lian-Li but that was all aluminium and quite thin compared to the 650D.
The cold breeze also feels great and because it's not summer, no worry of bugs flying in :p
It will report fan speed wrong as cpu header will monitor pump speed and thats the speed of your pump.
Ah right! Now I get that :p
I did rename the items btw, in configuration just highlight and F2 to rename items. As long as you know what header refers to what item, you'll be fine.
I used various other apps to seek out the header locations and also some online resources.
I have my PC next to window all the time. And my temps are 10-15C higher across the board :P
Son of a....!
quick question i've been using speed fan for months now, how do you rename things like yours says cpu-corsair h80
click on configure button.
You can rename almost any label in speed fan! Just select the label and left click on the selected label again (after a small pause)
