How much does a decent watercooling setup cost?
13 Oct 2004
Teesside
Hi Guys,
I'm considering trying out a custom water cooling setup for the first time, and wondered about how much extra it adds to a build?
I love the new Parvum 2.0 cases and so would likely use one of those...
Thanks,
Just to give you some idea for my blocks CPU and 2 GPU's with back plate's came to about
£300, CPU was £60 by its self.
How long is a piece of string? For a very much entry level build, it could be done for a couple of hundred, probably consisting of a very simple cpu only loop. I actually think I would cry if I totalled up the amount I have spent - and I have only been w/cooling since January '13. In that short 15-16 months I have built and stripped down to modify 3 times, as the urge to just make it perform and look better is highly addictive.
i spent about 200 quid for my cpu/gpu loop (cuz i purchased most of the parts with btc xD)
if not it woulda cost bout 450-500 quid
Just spent around 600 quid on mine, most of its just sat doing nothing atm as there are still some bits I need and when I start the build I would probably need to spend more money as it goes.
I think I managed to get some cheaper angled fittings, ek-psc and koolance, still I spent around 400£ on them. Probably another 600£ for blocks, pump, tubing, rads, fans.
For a high end CPU only loop, it starts around £180. It isn't cheap but waterloops are flexible and should have longer lifespan than anything else int he case.
