How much does the quality of a freeview box matter?
9 Jun 2006
Purgatory
I'm about to spend £100 on a 37" HDTV (good deal :)) but the catch is that it doesn't sport inbuilt freeview. So I need to buy a box. I see the price can range from £15 to over a hundred. I'm a poor student so am wondering what the difference is between the cheap and the expensive ones.
Other than a few added channels i cant see the difference. my mate has a £29.99 and a £69.99, top model and a low range model and the picture quality is just the same.
wouldn't bother with freeview anyway , check on the site to see IF / What is enabled in your local area.
Some freeview boxes can be a bit slow to change channels, or have menus/remotes that aren't totally intuitive - so check those if possible.
I had a super cheap one before we had a TV with it built in, was made by Sagem and was actually pretty decent.
I'd imagine the expensive ones are Freeview+ which would include the ability to record / pause live TV. Probably not worth spending a load on a Freeview box as FreeviewHD is on the way (unless said box includes FreeviewHD)
I've had cheap and not-so-cheap freeview boxes, and the more expensive one had faster menus and overall better firmware/interface. IIRC most boxes all carry the same firmware made by some company in turkey?
Tvonics have different firmware and the better interface, but I don't know if there has been much change in the last 2 years though.
Picture quality will be pretty much the same regardless of cost.
Your simply paying for the guide, connectivity and remote ergonomics
However my cheap one from asda has a good guide but lacks in the remote department
Another thing to bear in mind is if you want HDMI connectivity - normally a little more expensive to get this.
M.
Or just get a cheep one and bin it when freeview hd comes out. Not much point in having a non hd hdmi box.
