- 30 May 2009
- Maidenhead
Just wondering, how much fluid do you really need for a water loop? I am looking at buying the EK 250ml reservoir.
So, if I have that, a CPU block, GPU block, a triple and a dual rad, and a bit of tubing between that of course, how much fluid do you need?
I figure that since the water isn't endlessly circulating through the rad for extended periods of time when you flush it the chances of any significant deposits from the tap water building up are pretty much nil.
