Hi all!
Watercooling isn’t new to me, I am confident with about what I am to undertake though I haven’t touched WC in many, many moons – my last kit being a coolermaster aquagate probably - This will be my first time creating what i class a proper WC build.
I have bought a Lian Li v1000 Koolance chassis with a roof mounted 120mm x 480mm Rad.
I have sourced my waterblock and I have a koolance bayres/pump and relevant fittings.
The pipework is going to be quite long as the motherboard is essentially upside down in this case, meaning the CPU is going to be located near the bottom of the board/chassis.
Question 1 – With 10/13 tubing and my components can I estimate how much fluid I am going to have to order up? (I don’t want to order 1L, then find its not enough)
Ideally, I would like to install a drain plug near the bottom of my system. What fittings can you recommend for me to do this?
