Deleted member 70857
Hello, I like to think that I know how to go about overclocking and cooling etc.
To avoid the urge of upgrading, I feel like OC'ing my CPU a bit more if I can.
The PC is fine I dont NEED to upgrade. But you know how we all get that urge
The PC I have is in my sig if you would like to take a look.
Now I have currently got my CPU at 3.2ghz using 1.4v. I Have been on AMD's website and the max voltage for this CPU as stated on AMD's site is 1.4v.
If I OC any higher I start to get errors in Prime95.
My question is, even though it says that the max voltage is 1.4v. Can I go over this if the temps are good? At the moment on load I can keep the CPU under 50C. Also according to the AMD website the max temp is 63C
So do you think it would be a good idea to put some more volts in this baby and try to get some more juice out of it, if I can keep the load temps under 60C?
Also another quick question is. I have a 90nm chip and the max volts say 1.4v But the new PII are 45nm chips but can take up to 1.5v. I thought since the fab is smaller should it not have a lower max voltage?
Thanks
Thanks
