The server at work is a Dell Poweredge PE1850, 2.7Ghz with 1GB of DDR2 memory running Server 2003 Standard. Task manager reports that it's using around 650Mb
It's used for a number of things at the moment, including the company's website which is fairly low traffic at the moment, but that's expected to change. It's built using a mixture of ASP.NET, Classic ASP and SQL Server 2000. We run some fairly complex stored procedures on the data to generate crystal reports accessible via the website but they all generate in a matter of seconds.
It's also used as a basic file server (just using windows shares) and a mail server (hMailserver). There's also a DNS server on there which forwards everything but the company's website (so we can access it via xxx.yyy.com internally) to an external DNS.
Also, how much should I expect to pay? I saw one place selling 4GB of registered ECC for £165 or another set for £60 - obviously a vast difference.
Thanks .
Thanks .
