I'm working on the specifications for some new barebones crunchers and I'm not sure what the optimum memory should be for them, so I thought I'd ask some advice from my teammates.
I'm currently looking at a Intel Q6600 in a Gigabyte MATX board that I'm planning to remote-boot into Linux, probably Ubuntu using LTSP, and run the Linux Native SMP client. What I'm trying to figure out is whether to spec. 1 Gig or 2 Gig of memory for the cruncher, is it worth spending the extra money to go for 2 Gig, or will 1 Gig be sufficient?
This gets a bit more significant when you consider that I might be buying 4 of these babies. It might be the difference between upgrading one of my other crunchers or not (E6300 to Q6600).
