First of all, apologies because I know you get this all the time. But this is something that's been bugging me for ages (years in fact). I'll try to be as thorough as possible but please if you need more details, don't hesitate! I desperately want more juice.
First what btwholesale.com tells me:
"Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line rate up to 1Mbps. However due to the length of your line the 1Mbps service may require an engineer visit who will, where possible, supply the broadband service.
Our test also indicates that your line currently supports a potential ADSL Max broadband line rate of 4Mbps or greater. (Does this mean I have ADSL max?)
Your exchange is planned to have ADSL2+ by 31st March 2011 (ouch!). Our test also indicates that your line currently supports a potential ADSL2+ broadband line rate of 5Mbps or greater."
Now what Samknows tells me:
ADSL is available in your area
Your exchange is also enabled for ADSL Max services
According to BT Wholesale, your phone line should be able to support a 4Mbps or greater ADSL connection via ADSL Max.
Standard ADSL RAG results
You cannot receive 2Mbps ADSL (oh... can I take that as canon?)
You may be able to receive 1Mbps ADSL
You can receive 512kbps ADSL
You can receive 256kbps ADSL
You are approximately 2.24km from the exchange.
Stats from the router:
Data Rate (which I assume is the same as sync rate. This is a Belkin router btw.)
288 Kbps (Upstream)
1152 Kbps (Downstream)
Noise Margin
26 dB (Upstream)
13 dB (Downstream)
Attenuation
44 dB (Upstream)
38 dB (Downstream)
According to the sticky that limits me to 2Mbps. But perhaps thats not taking Noise Margin into account...
So I'm a bit confused about the quickest speed I can get. Perhaps someone can clear that one up.
According to the trial version of DUmeter I've been using this past month or so the maximum I ever get is 1Mbps. But I feel sure that in the past, several months ago, but no longer, I was able to download at close to 3Mbps.
We're with a little known provider called Direct Save Telecom and we pay for 8Mbps.
Their FUP is as follows:
UNLIMITED broadband usage off-peak. And a 20GB usage limit at peak time (between 6pm and midnight - duh).
According to DUmeter there was 18.8GB transferred (both incoming and outgoing traffic) between 4th March and today (29th). So its probably fair to round that up to a total of 20GB. So seen as the internet sees plenty of use during the day, surely we didn't go above our fair usage limit... But we're definitely capped at the minute - to speeds of around 10Kbps. Though all day today (I'm presuming they treat weekends the same as weekdays regarding peak time) I haven't got above 30kbps. And the capping seems arbitrary. Sometimes it occurs outside peak time and it seems to finish at 11pm as a general rule. And as you can see the extent of the capping can vary...
I have complained to DST in the past, but they just pointed me at Samknows and said that's all the speed you can expect. But I can't really interpret the info on Samknows...
I've heard its better if the router is connected directly to the 'source', the main phone hub thingy... Well our office is on the second floor and the router is connected to a bedroom port thingy (not sure what its called lol) which in turn is connected to the 'source'. Sorry for the hopelessly untechnical jargon.
I think also the ethernet cable can be a factor. My room is on the third floor and I hook up to the router via a cheap 20m cable. Also may be the router is a factor... (its a Belkin F5D7632 or F5D7633)
Phew! Sorry this is so long. Thank you so much if you're able to help me out. Though I have a feeling this is a helpless case. But like I say I'm certain that at times in the past I would download demos/patches from Gamershell (who seem to have decent servers) at over 300kbps...
288 Kbps (Upstream)
Noise Margin
26 dB (Upstream)
13 dB (Downstream)
Attenuation
44 dB (Upstream)
38 dB (Downstream)
