How much of a bottleneck is 4x PCI-E?
18 Dec 2004
North Wales
Just realised the second slot on my POS mobo is only 4x, I had it in the full speed slot previously but moved it lower to reduce temps.
My card is a GTX 660, other parts of my system are i5 760 with 12 gigs of ram
How much of a drop in performance have I given myself by using 4x instead of 16x?
Cheers
It's usually none. So long as it's PCI-e 3.0, 4x is absolutely fine, and there is typically nil difference. If there is it's negligible.
If it's PCIE3.0, 4x is effectively PCIE2.0 8x and you'll be fine. I showed that recently with a dodgy 780
If it's PCIE2.0 x4, then you'll be losing some decent fps
Motherboard is a BIOSTAR H55A+ socket 1156, it's PCI-E 2.0
So I ran 3d mark 11 with the sky diver test, I disabled all but one monitor for the tests
4x as it was:
11689 points
16x
11906
So not even 2% difference, thought that was a little weird so I opened up GPU-Z and it's reporting the card is only running at 8x?
I guess that could be some power saving feature :o
I think I may as well move the card back, but I'll wait a week or so and see how the temps are
This is what I'm running:
2x4GB and 2x2GB, that's dual channel isn't it? I got lost with components after DDR1 went :D
