Hi, my 920 OC settings use as a guide X58 UD5A mobo -
BIOS SETTINGS 4.0GHz -
Adavanced CPU Features - [A = AUTO][E = ENABLED] [D = DISABLED]
CPU CLOCK RATIO----------[a] - 4.0GHz - [21]x191 / 4.2GHz - [21]x201
INTEL(R)TURBO BOOST------[A] - E
CPU CORES E------------[ALL] - ALL
CPU MULTI THREADING------[A] - E
CPU ENHANCED HALT (C1E)--[A] - E
C3/C6/C7 STATE SUPPORT---[A] - D
CPU THERMAL MONTIOR------[A] - E
CPU EIST FUNCTION--------[A] - E
VIRTUALIZATION TECH------[A] - E
BI-DIRECTIONAL PROCHOT---[A] - E
UNCORE & QPI FEATURES -
QPI LINK SPEED-----------[A] - 36
UNCORE FREQUENCY---------[A] - 17
ISONCHORNOUS FREQUENCY---[A] - E
INTERGRATED PERIPHERALS -
ICH SATA CONTROL MODE----[IDE:ACHI] - ACHI
STANDARD CLOCK CONTROL -
BASE CLOCK[BLCK]CONTROL--[A] - E
BCLK FREQUENCY [MHz]-----[A] - 201x20=4.2GHz / 191x21=4.0GHz
PCI EXPRESS FREQ[MHz]----[A] - 101]
C.I.A.2------------------[A] - D
ADVANCED CLOCK CONTROL -
CPU CLOCK DRIVE----------[a-OPS] - 800mv
PCI EXPRESS CLOCK DR-----[a-OPS] - 900mv
CPU CLOCK SKEW-----------[A-Ops] - OOOMV
IOH CLOCK SKEW-----------[A-Ops] - 000MV
ADVANCED DRAM FEATURES -
PERFORMCE ENHANCE--------[A] - TURBO
EXTREME MEMORY PRO[XMP]--[A] - D
SYSTEM MEMORY MULTI[SPD]-[A] - 8x=1608mhZ
DRAM TIMING SELECT[SPD]--[A] - EXPERT
CHANNEL A+B+C TIMINGS SETTINGS[ALL THE SAME] -
##CHANNEL STANDARD TIMING CONTROL##
CAS LATENCY TIME---------8 [A] - 9
TRCD---------------------8 [A] - 9
TRP----------------------8 [A] - 9
TRAS--------------------24 [A] - 24
CR-----------------------2 [A] - 2
##CHANNEL ADVANCED TIMING CONTROL##
TRC----------------------[A]
TRRD---------------------[A]
TWTR---------------------[A]
TWR----------------------[A]
TWTP---------------------[A]
TWL----------------------[A]
TRFC---------------------[A]
TRTP---------------------[A]
TFAW---------------------[A]
COMMAND RATE[CMD]--------[1]
##CHANNEL MISC TIMMINGS##
ROUND TRIP LATENCY-------[A]
ADVANCED VOLTAGE CONTROL - 4.0ghz - LLC=L1 - Vc-1.32v / 4.2ghz - LLC=L1 - Vc-1.33v
CPU VOLCORE - 4.0ghz - LLC=L1 - Vc-1.32v / 4.2ghz - LLC=L1 - Vc-1.33v / DYMANIC VCORE[DVID]------[0+00000v auto]
CPU-
LOADLINE CALIBRATION-----[a] STANDARD - LEVEL 1 - LEVEL 2 - ENABLED TO Level 1 = 4.2GHz / 4.0GHz
CPU VOLCORE--------------[0.00000v]
DYMANIC VCORE[DVID]------[0+00000v auto] to set DVID = NORMAl/[1.3250- 1.25625 = +0.06875v DVID] 4.0GHz
QPI/VTT VOLTAGE1.150v----[A] - 1.315v
CPU PLL 1.800v-----------[A] - 1.800v
MCH/ICH -
PCIE 1.500v--------------[A] - 1.500v
QPI PLL 1.100v-----------[A] - 1.140v
IOH CORE 1.1v------------[A] - 1.120v OR 1.100V
ICH I/O 1.50v------------[A] - 1.500v
ICH CORE 1.1v------------[A] - 1.140V OR 1.00V
DRAM -
DRAM VOLTAGE 1.500v------[A] - 1.540v
DRAM TERMINATION 0.750v--[A] - 0.750v
CH-A DATA VREF---0.750v--[A] - 0.750v
CH-B DATA VREF-----"-----[A] - --"--
CH-C DATA VREF-----"-----[A] - --"--
CH-A ADDRESS VREF-0.750v-[A] - 0.750v
CH-B ADDRESS VREF---"----[A] - --"--
CH-C ADDRESS VREF---"----[A] - --"--
Oldphart.
