How Much power and going modular help
18 Mar 2007
Currently have an old Non Modular 800 W Seasonic PSU
Due to graphics cards issue, going to to change it to modular.
What modular and level of power do you think i need to run the below???
(Considering a 280gtx has a weird 6+8)
i7 920 OC to 4GHZ
6GB RAM
SDD+2 7200 RPM DRIVES
280GTX
P6T DELUXE
5 USB DEVICES
2DVD RW's
PS: is their any modular PSU that i can go straight from 6pin to 6pin and 8pin to 8pin???
BFG cards come with a 6-8 pin converter, and you can buy then if you look around.
Your PSU is decent, I would look at a cable conversion rather than buying a new PSU.
I would look to get an adaptor cable first and see if you could run the GTX280 off your existing PSU.
A decent 800W PSU will run an overclocked Core i7 920 and a pair of HD5970 graphics cards:
http://www.techpowerup.com/reviews/HIS/Radeon_HD_5970_CrossFire/2.html
I would suggest the Antec Signature 650W:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-104-AN
It is made by Delta Electronics and has very good reviews:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=113
http://www.hardwaresecrets.com/article/658
