How Much Power Do I Need?
31 Aug 2010
Hi,
Building my first gaming rig soon and I had a question for the more experienced people out there, how big of a cpu do I need for a computer with a hex core and crossfire hd 5870s, I was initially thinking a 850w?
If you can be any help I would appreciate it.
Cheers,
Naz
Hi Naz,
850 is probably a little overkill, 700 should do you fine.
Just a note - you put "cpu" instead of "psu"... hopefully you won't get them mixed up when you order!
