To keep things remotely applicable to the everyday user, I'd like to restrict the question to above ambient cooling, one cpu, two graphics cards.
I'm reasoning about 200W for an i7, 150W per card, rest negligible. At a 80% efficient psu, that's (200+2x150)/0.8 = 625W from the wall at full load.
This site thinks my processor uses 300W, which I don't believe, and as far as I know it's about as good as online calculators get.
So, any ideas, measurements, or sources that might lead to the answer?
Also interested in any reasoning why you believe this figure will go up or down over the next couple of years.
Found a 280gtx review which disagrees with me: guru 3d.
Our test system contains a Core 2 Duo X6800 Extreme Processor, the nForce 680i mainboard, a passive water-cooling solution on the CPU, DVD-rom and a WD Raptor drive. The results:
* PC in Idle = 197 Watt
* PC 100% usage (wattage gaming Peak) = 530 Watt (SLI)
* PC 100% usage (wattage gaming Peak) = 749 Watt (3-way SLI)
Found a source Here based on an es sample of an 920 that puts 3.8ghz, 1.5V at 311W.
Convincing article about processor power draw here. It's more complicated than taking the TDP value it seems.
guru 3d said:GTX 280 can consume up-to 237 Watts per card when 100% stressed
