How much power does your NAS use?
7 Jul 2004
Gloucester
Mine is pretty simple and just used as a Plex server. I built it with spare parts I had lying around which I had intended to sell on the MM so it wasn't carefully thought through or anything
i5 8500 for Quicksync
Z790 mATX motherboard
16GB ram
2TB NVME for OS and Plex cache
2x 18TB Western Digital drives shucked from ByBook's or whatever they're called now.
Windows 10
I'm not running raid, I have a couple of USB enclosers separately which has a copy of everything that goes onto Plex. This is to keep the any noise to a minimum and I like the idea of an offline backup.
Now to get to the point of the thread, this setup is using 27w of power continuously, 24/7 and averages 0.71kwh per day
Is this bad? Would it be worth moving this into a proper NAS with some proper thought instead of just something quickly thrown together?
What kind of power usage would I get with a dedicated NAS, designed to be a NAS?
This has been running 24/7 for 3 years now, with just the occasional reboot roughly every 4 or 5 months when I decide to run a Windows update
27 watts is nothing. If you think that a spinning HDD is going to use at least 5w, that leaves you with 17w for the rest of the system. Even spending hundreds and hundreds of pounds on a pre-built Synology, you will be talking pennies in terms of power savings.
My first NAS (ok, tbf it was a VMWare ESX box running a bunch of VMs) used to consume about 150w. Some years later and several revisions and I am down to about 45w with a Ryzen 4650GE and a pair of 14TB Toshiba drives, and I don't even give it a second thought. My network switch uses more power than my server.
I have Unraid running on an N100 Topton board, 2 * NVME, 3 * 3.5 HDD. Burbles along at 23W with the HDDs all parked and will rise to ~34W when doing stuff that spins some of them up.
I'd hoped it would idle lower but it's good enough for me and the more aggressive power saving measures in Unraid either don't work or have no impact.
Ok, that's good. Cheers.
I feel better now.
I was questioning it because I had somebody questioning me on it. You know, the usual "isn't it expensive having a PC running 24/7", "surely that's a waste of money" etc.
Was wondering if there was a better way, but I see it's all good :)
I feel better now.
0.71kwh per day is only about 15p. £4.50 a month roughly. If you’re worried about £4.50 a month then computing is t the hobby for you ;)
CPU - AMD Ryzen 3 3200G
RAM – 32GB 2400MHz (2*16GB)
MB - Gigabyte A520I AC
GFX - intergrated Vaga
5xSeagate IronWolf 10 TB NAS Internal Hard Drive HDD
Network - Intel X540-T1 RJ45
Power supply - Be quiet 300W
Draws about 56W at idle and 119W max running TrueNAS Scale with a couple of Docker Containers.
That's without drives.
Ah. Yes. My googling wasn't quite as in depth as it should have been. Got a couple of WD Reds in there. So that's gonna bump it up a bit.
Edit: Another very quick google suggests each drive could be using another 8 or 9 watts. So probably around 30 watts in all. (ish) :)
I have a basic raspberry PI 4 NAS with just a single HDD and SSD attached. I think it's around 3-4 Watts, maybe a few more if the HDD spins up.
I think this is the ultimate in lower power nas solution for light/medium use. Really cant beat <5 watts including drives by using anything else.
I have a few, but one is pulling 48 watts at the wall currently with a UPS in the way. Or at least that’s what the PDU is reporting. How accurately the power is being read is pretty questionable and I’d say it’s reading a little low.
5750GE
64gb
Two Intel P4510
8 3.5” HDDs
10gigabit nic
I have a self built NAS with a 9500t and 6 drives. the UPS its connected to reports its using around 350 watts a day on avarage over the last week.
It's definitely more than 5w when the HDD is spinning a 3.5" drive uses around 5w or more on its own.
When you get down to sub 50 watts you really have to start questioning the accuracy of the readings. At that point you’d need calibrated equipment and piercing probs to have any level certainty in the numbers. 5 watts simply isn’t possible with any off the shelf PSU.
Mine is read using a smart plug the NAS is plugged into. The 27w is an average over the last month and 6 months
What passes for a NAS in my current setup is a MeLE PCG35 with J4125 CPU, with Samsung 2TB SSD and 2TB NVME internally, doing real time replication to a pair of external HDDs. With everything spun down it is around 3 watt (yes actual) draw at the wall, or around 7 watt average in nominal use up to ~20 watt under heavy load - which is rare for its usage. I'm now using it with a UGREEN US3000 UPS - I've not yet measured at the wall to see what the power consumption is with that in the mix.
