I was thinking about buying most of a new computer and I was wondering if I can keep an old PSU. It's 520W (NesteQ NA 5201) so
Then either use the old disc system
Edit: Got the bundle wrong...
It would be in a Lian Li Pc V2100, which means the cable run from the PSU to the components needs to be quiet long
Or replace with a smaller number of big discs.
- Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz overclocked up to 4.00GHz!
- Asus P6TD Deluxe Intel X58 (Socket 1366) DDR3 Motherboard
- Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9)
- Titan TTC-NK85TZ Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366)
- Arctic Silver 5 Thermal Compound (3.5g)
- Sapphire ATI Radeon HD 5870 Vapor-X 1024MB GDDR5 PCI-Express Graphics Card
- 3ware Escalade 9500S-12 Storage controller (RAID)- Serial ATA-150- 150 MBps
- 5 * 500GB disc
