How much quicker is a socket 1155 i7 over an i5?
Hmm... very differing opinions.
Really???? Assuming the same clock speed....
  • For a single threaded app, the only potential difference will be a possible slight increase if the extra cache helps. This will be dependant on what's going on in the rest of the system and is likely to be a negligible performance improvement.
  • For apps that have 1-4 threads, the improvement will be subtle at best and only due to the previous quited bigger cache.
  • For apps that have more than 4 threads, it will be dependent on the application. Something like prime which just spins in an everlasting loop doing calculations, it will be almost a factor of 2. More meaningful apps - like video encoding - you get an improvement of ~10% but only if the process is compute bound. When I recode video on my i7, the first pass is I/O & interprocess comms bound. It is actually slightly slower with 8 threads compared to 4.
Fundamentally, unless you do a lot of heavy computing that you know will benefit and/or you want i7 vs i5 bragging rights, the i5 is the smart choice (clock speeds excepted of course)...
No not really ard85.
I very rarely convert video and 10%~ +/- performance is pointless anyway.
So in a desktop environment an i7 is the same as the i5. Buying one for a home based system is getting nothing for something and even if you did a lot of AV editing you would see little improvement?
That about sum up the i7?
Yes.
But you said "Hmm... very differing opinions.". The way I read the replies, it sounds like everyone is saying the same thing so I summarised my understanding.
If you'd have said, "Hmm... not much point then." I wouldn't have posted ;)
I do a lot of converting home videos to DVD and I have found that having HT on, and therefore showing me 8 cores, is hugely beneficial to me having it off.
Plus its placebo I will admit. 8 must be better than 4 after all, but then in the apps I use, it certainly is.
so, in english money, disabling hyperthreading on an I7 turns it into an I5 and so, clock for clock, I would say that no, the I7 is better, but as I said... Only for some apps and in my case, its video processing.
[/i] if the process is compute bound. When I recode video on my i7, the first pass is I/O & interprocess comms bound. It is actually slightly slower with 8 threads compared to 4.
[/list]
I'm quite surprised on your suggestion of ~10% speed increase due to hyperthreading for video encoding. In my experience it's a massive improvement of about 80% depending on the codec and application used to encode?
In Adobe media encoder CS6 for instance it can make a big difference, you have to make sure the computer IO can keep up with the encoding, but that's typically not an issue these days.
But 100% Agree that unless you're doing a LOT of video encoding or 3D rendering, going i7 over i5 is probably a waste of money.
E-I
You are only going to see benefits in applications that max out the 4 physical cores, even for example an 8 threaded game will run just fine on a non-HT quad core as long as usage is below 100% (it generally is in games unless heavy number crunching takes place). For example games like Civ 5 which do heavy processing between turns will benefit from HT.
Well.. perhaps I should have said 20% rather than 10%, but definitely not 80% (all my encodes are recodes of HD from the TV). The benchmarks tend to agree too:
http://www.anandtech.com/show/4083/...core-i7-2600k-i5-2500k-core-i3-2100-tested/16
(I chose that as I know it was there).
I use x264 (via ffmpeg) to encode. It's a pretty reference implementation of a modern encoder.
80% is certainly optimistic.
but I also think that 20% is a little low for the other end too!
Depends on the app running the task
It does. But most tasks most people run cannot be run efficiently as 8 tasks that don't interact and don't fall over themselves. If every app was like prime, then yes, go ahead, but the real world isn't like that ;)
Looking back at those benchmarks, POV and x264 are the ones that stand out as the largest increase in performance i7 over i5. x264 is probably<20% (by the time you factor 2 passes in). POV is 40%ish (but ray tracing is great for being run in parallel). Chromium compile is 50% quicker, everything else basically falls into the ~10-20% mark.
