I've always used a Rice grain sized amount smack bang in the middle of the CPU![]()
I get a thin plastic bag and stretch it over my finger and rub it across the cpu heat spreader. very finely 100% coverage.
This is what I do, works the best.TaKeN said:I've always used a Rice grain sized amount smack bang in the middle of the CPU![]()
The heat comes from around about the center of a CPU. You don't need the whole thing covered, which is why the line down the middle or the pea/rice grain method works just as effectively.
I find it fairly surprising that people are even suggesting spreading it with their finger or a plastic card.
Man this pics old... dunno what Nvidia was thinking putting that much on.![]()
Why do you think the metal cover on CPU cores is called a 'heatspreader'? more surface area between CPU & heatsink means a more efficient heat transfer so spread method should improve heat transfer in theory.
It doesn't make a great deal of difference how you do it, lots of theories about air pockets etc but in practice they're all more or less the same... some prefer a small blob others prefer to spread for maximum coverage.
There's nothing wrong with it, as long as it's not conductive the excess doesn't have any negative impact.
At least they aren't being stingy.![]()
I used this method everytime too, the trick is not to use too much.
Otherwise it'll end up looking something like this!
