Caporegime
- 13 May 2003
- Warwickshire
How much to replace a secondary (DHW) heat exchanger on a combi
Hi all
We have a Ravenheat CSI 120 T Low Nox combi boiler. It's awful and we're getting it replaced next year when we do the kitchen, but in the mean time...
Our hot water is cycling hot and cold. Observing the boiler I can see that it's shutting down then kicking back in again repeatedly, which is apparently a classic symptom of a blocked DHW plate heat exchanger (probably caused by a filthy system).
I've called a heating company out to come and take a look, but how much is reasonable for a job like this so I know if their quote is OK?
The part alone is about £150
. There's a pattern part on the good old internet for about £40!
Can anyone tell me a sensible ball park guide price? The manual makes it sound like a fairly simple job.
Thanks.
Hi all
Thanks.
