how much to spray..
1 Mar 2006
the rear door of a mk3 mondeo
basically had a little run in with a wall and ruined the rear door.
so i went to ebay and bought a new one ...bargain at £60 but the picture was abit misleading and the colour is wrong
if i was to put that other door on how much would you expect to pay for someone to spray it the same blue as the car?
would they really need to blend in with the wings etc?
thanks
My lot charge 200-300 quid per panel if theres no damage.
where would i find the paint code?
i thought id found and matched it with the ebay auction b5y...turns out that means 5 door hatch :(
Let the body shop match it from swabs dont worry about your paint code.
i was just thinking of trying to find a totally new door on ebay which will probably work out cheaper if i can match the paint this time..
as no ones going to want £300 for a second hand door
thanks
