How much to upgrade?
Caporegime
3 Jan 2006
Chadderton, Oldham
I'm planning to overclock.
I've got a good GPU (5870) and hoping the PSU will be ok (HX520W Corsair).
So all I'm really needing is an i7, mobo and ram, and wondering how much at the cheapest I can realistically be looking for this?
Don't know what sort of i7 I should look for but I'd like to get one that can hit 4GHz and I'm guessing I'd need 6gb of ram too.
Any help would be good.
Cheers.
what are you using the PC for? if its gaming, then i would say i5 2500k, p67 mobo and 4GB RAM.
for video editing, or any other CPU intensive stuff i would say i7 2600k, Z68 mobo and 8 or 16 GB RAM
Well if you decide to go the i5 2500K route with 4Gb of RAM your looking to spend around £330. With 8Gb of RAM it's £370.
If you're set on the i7 with the 2600K with 8Gb of RAM it's around £470.
Depends what you need it for but it's mainly for gaming I'd recommend the i5 build.
Will and i5/i7 overclocked be ok on a Corsair HX520w?
Should be fine with a single 5870 as it's a very good quality seasonic based unit, nice and efficient even at full load too ;)
5870 Review
Our test system is a power hungry Core i7 965 / X58 based and overclocked to 3.75 GHz. Next to that we have energy saving functions disabled for this motherboard and processor (to ensure consistent benchmark results).
Our ASUS motherboard also allows adding power phases for stability, which we enabled as well. I'd say on average we are using roughly 50 to 100 Watts more than a standard PC due to these settings and then add the CPU overclock, water-cooling, additional cold cathode lights etc.
Keep that in mind. Our normal system power consumption is much higher than your average system.
System in IDLE = 169 Watts
System with GPU in FULL Stress = 358 Watts
Sounds like a plan, the motherboard in your sig is up to it too.
Someone is selling a 5870 for £70, but I think it causes issues at its full clock speed.
i7 2600k with 8gb ram would be the way to go if you have the cash or if can wait till aug/sept for BD to come out, the prices for i7's might go down.
AMD Bulldozer, which looks like its been delayed again, The 6core phenom chips cant compete against the Sandybridge either.
From reading around it seems at the moment there may be no point even doing anything unless I want to go crossfire, perhaps 4gb extra ddr2 ram on the cheap and a 1TB hdd.
Might just have to keep waiting for some good buys.
