about to knock down a wall between lounge and kitchen.
i thought to take the wall as fas back as possible (ie remove as much of it as we can to just leave enough for the joist to sit on)
getting advice to leave the wall still coming out 600mm (same as the kitchen units will come out)
here the middle option would leave a 600mm wide wall, but floor to ceiling , so if you were in the lounge looking to the kitchen the units would be hidden and you wouldnt be able to see the worktops
right option is more what i imagined, leaving it more open so you can see down the worktops and imo give a feeling of more space
another example how i imagined it
the bit at the bottom of the photo/ looking at the sides of the units/ (not the walls at the top)
