How much Water Wetter?
20 Nov 2004
UK
About to get my WC up and running. I have a 92.1 w/ Waterchill block and a MCP650. Only have one block on the loop. Ive got a 25ml bottle of Water Wetter but was wondering how much of it i should put in? Is there a ratio of Water Wetter : Distilled water I should try and follow?
Ta
Water wetter reduces the effects of surface tension and cohesion of the water (making the water wetter... geddit? :p). reduced cohesion = better contact with waterblock = better cooling
I'm not sure if there's such a thing as too much Waterwetter I'd do what the instructions say, usually it's somthing like 25ml added to a litre or 500ml or somthing. It's certianly possible to have too little... (no real adverse afects though)
There should be instructions on the bottle/syringe it came with.
jidh007 said:
Edit: But typically too much won't make too much difference, I don't think?
I sure hope not.. i've got about 1 part in 10 too much in my system... but it's running cooler than when it was just water... admitedly we're talking single degrees at load, but every little helps :D
btw... nice sig jidh007 :D
