Not sure of the power draw on an unlocked 6950, but my rig with the same spec other than being watercooled and an 8800GT instead of your 6970 draws 280w at the wall. I'd say JonJ is about spot on
I think the CX400 will probably cope. If the psu fan is ridiculously loud or it starts rebooting under load then you have good reason to worry, but otherwise I'd be inclined to give it a go. That corsair is about as good as 400W units get.
