how noisy is stock cooler on powercolor X850XT
17 Nov 2005
on a rock in the irish sea
hello, just bought a Powercolor X850XT as part of a new set up & before building would like to know if the stock cooler is noisy or not. i am looking for quietest solution so considering a zalman kit or something but not sure if any advantage over stock cooler. can someone with one of these cards reply please, thanks ;)
thanks AnastieByte, i think i will probably hold back on buying now until ive built & checked it for noise
normal mode was ok but in use sounds like a damn spitfire :(,one i had was anyway rest of card was fine though and a artic cooler sorted the noise out :)
use ati tray tools to reset the fan setpoints and the stock cooler will be fine. After a play with my settings mine will idle at 34'c - fan at 35% and under load hit 63 max - fan at 65%.
Depends on how quiet the rest of your PC is and how noisy it needs to be to annoy you. Personally i had to play games using earphones because of the whine it made till i changed it for a zalman cooler.
Zeph.
