How often are you cleaning your PC?
11 Aug 2007
Preston, Lancashire
How often does everyone do some cleaning and maintenance on their PC?
Dusting, changing CPU paste ect.
Does it change if its used more often for gaming? If your PC is left on 24 hours?
I did a clean after a year or more, and it made a huge difference to temps. The fans spin up less often for the AIO.
Main PC (at desk level) blow rads out and clean filters maybe every 6 months. The loop is due a drain/flush and check over soon, will probably repaste the CPU when it's drained, along with the GPU, and probably repad that as my hotspot delta is slightly higher than I'd like. Prolly give the fans a wipe then as well as a bit of a dust inside as well.
NAS - opened up to change a noisy fan, gave it a quick once over then, otherwise pretty much never
Server (on the floor, I know, I know) vacuum the front maybe once a month.
Servers which are in the loft and doesnt get much dust I just leave, my desktop PC which is on 24/7 gets a filter dust and fan blow every couple of months or so.
I give it a thorough dust when the weather gets hot, otherwise just hoover the dust filter when it occurs to me. I never replace paste (maybe I should but it hasn't mattered so far).
Every 6 months or so. Usually when I can see too much dirt in the way of the fan leds.
Not nearly as much as I should. I saw a place advertising on FB to clean your PC for £40... Didn't even know "detailing" a PC was a thing :p
Regularly clean the outside of the case, air vents, glass panel and such.
I did do the inside a few months ago when i swapped my NVME drives around, but to be honest there wasn't much dust anyway.
every time i do a major upgrade.. e.g. bleeding water loop or rebuilding.. typically every 2-3 years.. unless i see a performance change or rig getting toastier, i check the fan filters
