Hi guys.
I'd really like to build my own rig, (i intend to change after Xmas as should have saved the cash by then) and overclock it a little. However, the one thing that puts me off is the risk of component failure and what to do when things go wrong as i don't have access to other compatible components to swap across and test things with.
My own PC was built by a mate but not without diffs as follows-:
CPU would not run at its recommended speed without crashing about once every 2-3 hours. After a week of this system had to be reformatted. It ran fine if set a fraction faster or slower.
In same batch memory was faulty and had to be returned.
A couple of years later i got Radeon 9800 pro which also had to be returned.
Regarding the first system i owned, the monitor was replaced 3 times in its first year and a 4th time a week before the extended warranty ran out!
So although i'd like to build my own, i'm starting to think a pre-built system would be a lot less trouble!
