- 28 Oct 2006
- stoke on trent\bromsgrove
well folks i have used this coolant in my pc for all most 2 years now !.
& my temps have gone up a bit, so maybe it is time for a strip down & clean out.
so how often should i change my feser coolant ?, or better still is there anyone near stoke on trent who can help me make my water cooling lope better, as i have a pigs tail & that what needs sorting out.
but i am too worried to try it my self, plus i have a new wc block for the 280gtx what needs installing too.
any takers, but you must be good at WC........ ( as i will be paying you ! ).
thanks
i7, 920 cpu clocked to 3.60, asus p6t deluxe oc palm edition, 6GB corsair xms3 pc3-12800c9 running at 1604 MHz, zotac geforce gtx 280 amp 1024mb gpu Stock speeds, modded coolmaster master rc-1100 cosmos s case Water Cooled, enermax galaxy 1000w psu, along with 3x 500GB WD drives 1 for xp pro 64 bit sp2, 1 for vista ult, 1 for W7 ult ( action pack release ), & a 1TB WD drive for back ups & some music.using a hp lp2475w monitor.
thanks
