How often to renew thermal paste?
31 Oct 2007
Gods County(Allegedly)
Am looking over xmas to drain down and refill my watercooled system.
Thought occurred ' should I clean and re-new thermal paste?'
Answer to self was 'why not?' BUT then thought about having to replace the gpu/vrm's paste - a NOT !!
Unless, of course, it is an essential ??
Am running with MX4 - about 18months old - temps still appear good.
Thoughts appreciated - how often would you recommend renewing thermals?
Only if I see temperatures rising above what they normally are - properly applied I've had systems running for years with the same idle and load temps for a given ambient.
Thanks for the replies :)
Have decided to leave until it is due for reason of temps. increase or otherwise needed (not just because of the passing of time)
any recommendations for cleaning away old thermal paste? does it go hard or can you just wipe it off with a cotton bud?
I tend to take down my water cooling loop once a year for a quick clean...
If I was on air cooled or an AIO water cooler, I don't think I'd bother myself.
